Dana 60 posi unit with no tone ring provision?
Old Mar 16, 2018 | 07:48 PM
AtomicDog's Avatar
AtomicDog
Angry Dana 60 posi unit with no tone ring provision?
I'm trying to install a new 30 spline Dana 60 power loc unit into a 2001 Dana 60 HD rear housing, but finding that the new Dana 60 power loc unit does not have a provision to install the tone ring. Has anyone run into this before and what can be done to rectify this issue short of getting a Dana 60 power loc unit with a tone ring provision? Also, what would I be losing if I don't install the tone ring? My truck is an early model 1996 Ram 2500 4x4 with rear ABS that I'm planning to install this Dana 60 HD into (since it has rear disc brakes) - I guess I would expect to get some sort of ABS check light, but wondering if anything else is affected by this issue. Thoughts?
Old Mar 17, 2018 | 03:18 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
You will have no ABS that is it which will set the ABS and BRAKE light that's weird the 2001 doesn't have a tone ring...
Old Mar 17, 2018 | 08:40 AM
AtomicDog's Avatar
AtomicDog
The original open carrier in the 2001 Dana 60 HD has a tone ring. Unfortunately, the new 30 spline Dana 60 Power lock unit I purchased is for non-ABS Dana 60 housings and I didn't realize it until I went to get things installed. It seems they make the 30 spline Dana 60 power lock units in either ABS vs non-ABS flavors.
Old Mar 17, 2018 | 09:10 AM
Moparite's Avatar
Moparite
You may be able to use this. Might need to modified and welded on.???
https://eastcoastgearsupply.com/i-18...ing-42928.html
Old Mar 17, 2018 | 12:45 PM
I would swap the carrier for the correct one..... maybe..... not like the rear wheel abs on these trucks actually does any good..... could just disable the abs system altogether....
Old Mar 17, 2018 | 04:07 PM
true blue's Avatar
true blue
If the powre lock housing won't fit the ring, don't weld anything, you'll mess up the side to side adjustment ratio...also effecting proper backlash and ring to pinion gear contact pattern. Better to leave the ring gear out or replace the carrier with the proper one.
Old Mar 17, 2018 | 08:44 PM
AtomicDog's Avatar
AtomicDog
Unfortunately, looks like I need to pick up the correct power lock carrier if I want the tone ring in place. I spoke with my rear end setup guy and he's saying the same thing.
Hope sharing this information makes others aware that they make ABS and non-ABS versions of the posi units for these rears to save others from the pain I'm experiencing.
Old Mar 18, 2018 | 12:26 PM
AtomicDog's Avatar
AtomicDog
Well, I'm not done yet. Looks like I might be able get my Dana 60 power lock carrier modified to accept the tone ring. After visiting with my rear end setup guy, it appears that the outer edge of the carrier that the ring gear bolts to would need to be turned down slightly and a notch cut into it. I know a few machinists with large lathes and skills that may be able to take care of this issue. Stay tuned.
Old Mar 18, 2018 | 12:49 PM
Will that void the warranty on the carrier though?
Old Mar 19, 2018 | 12:27 AM
AtomicDog's Avatar
AtomicDog
What warranty? I bought the power lock unit off an eBay seller (who had it sitting on his shelf for who knows how long) last year and finally got around to getting the gears setup on it recently. I'm kinda stuck with it, so I might as well use it if one of my machinist friends can work their magic.
