Cracked transfer case
Old Mar 18, 2018 | 01:53 AM
Msgkain1's Avatar
Msgkain1
Default Cracked transfer case
2001 Dodge 1500 4x4 no lift kit. Bought the truck at an auction. Found out it had a cracked transfer case (Rear part of the case). Got a used transfer case at a pick a part. Had it completely rebuilt and a steel rear drive shaft made for it (the one on it had dents) from a place that builds drive shafts. 4k miles later, the case is cracked in the rear again. The shop is sending the shaft back to check the balance. Is there any other thing that would cause it to crack.
Old Mar 18, 2018 | 09:20 AM
Age, casting flaws, abuse by prior owners, lack of lubrication, bad luck.
If you weren't feeling a vibration, likely just the last option.
Old Mar 18, 2018 | 02:42 PM
2bit's Avatar
2bit
Transfer case saver
https://www.google.com/url?sa=t&rct=...sj0Z26jbUAWH9L
Maybe consider new engine and transmission mounts.
Old Mar 18, 2018 | 07:34 PM
Sheriff420's Avatar
Sheriff420
Is it housing where the driveshaft slips into the transfer case that cracked? I wonder if it's an absent snap ring issue. like the issue that inspired the transfer case saver to be created.
Old Mar 19, 2018 | 04:49 AM
Msgkain1's Avatar
Msgkain1
Default Thank you for the feed back
I am going to call the shop tomorrow and ask for them to check my mounts.
Old Mar 19, 2018 | 04:58 AM
Msgkain1's Avatar
Msgkain1
Default Transfer Case Saver
Just Googled the Transfer Case Saver. I think I will tr ity. As for where it cracked...the backside of the case where the shaft to the rear wheels comes out.
Old Mar 19, 2018 | 04:09 PM
2bit's Avatar
2bit
Seems odd that two transfer cases cracked. That leads me to think it's the mounts or some other vehicle problem. I have the T-case saver in mine, it's cheap insurance.
Old Aug 7, 2018 | 07:35 AM
Fergus's Avatar
Fergus
Default Does it look at all like this?
I replaced one six months ago for an Identical hairline crack all around. This is the second one. Looking for answers on this one. Heavy vibes between 55-65 and when letting off the gas.
Is the snap ring still in place on the output shaft?
Old Aug 7, 2018 | 07:53 AM
Fergus's Avatar
Fergus
Having it towed I'll take a look when It gets to me.
