Trailer light connection
Old 03-23-2018 | 07:49 PM
schmidtp's Avatar
schmidtp
Default Trailer light connection
Hi All,
Where can I find a trailer light diagram? The previous owner jacked up all the wiring. I got both turn signals and the lights to work. But once I press the brakes the lights go off. I'm sure this has been asked before but any google search didn't do me any good. 1998 1500 Laramie.
Thanks,
Old 03-23-2018 | 08:56 PM
Moparite's Avatar
Moparite
Do you have trailer tow package?
Old 03-23-2018 | 09:12 PM
Have the service manual for your truck yet? If not, download one from the thread in the faq/diy section.
Old 03-24-2018 | 02:01 PM
schmidtp's Avatar
schmidtp
Can I tell that from pulling up the VIN? I just had the old hitch rust off the truck with my dad's new pontoon attached on the highway, fun times, and I am trying to get everything back together for a UHaul since I am looking for a house.
HeyYou I will pull up the service manual and see if that helps.
Thanks guys!
Old 03-24-2018 | 02:04 PM
schmidtp's Avatar
schmidtp
Vin 387hf12z8wm221810
Old 03-24-2018 | 10:30 PM
VIN is not correct.
Old 03-24-2018 | 10:54 PM
crazzywolfie's Avatar
crazzywolfie
have you checked to make sure the trailer connector has a good ground? i would maybe even double check to make sure you got the connector wired properly. you could use either a test light or a multi meter to do so. test every wire 1 at a time. if it is all wired right at the connector it is possible the issue you were having might have been with the trailer.
Old 03-25-2018 | 01:25 PM
2bit's Avatar
2bit
Is this what you're after?
Old 03-27-2018 | 02:47 PM
schmidtp's Avatar
schmidtp
Thanks for the help. I will try to take another look at it sometime this week. Hopefully I can get a picture to show you guys what I am dealing with. There is a whole bunch of splicing from whoever owned the truck before.
I also has a typo on the VIN: 3B7HF12Z8WM221810
Old 03-27-2018 | 03:15 PM
Heavy Duty Service Group
Trailer Tow Group
Heavy Duty Engine Cooling
P265/75R16 OWL On/Off Road Tires (and 3.55 gears)
So it's pretty much set up as a tow vehicle.
Quick Reply: Trailer light connection
