p0351 error cleared now code not returning
Old Mar 26, 2018 | 11:28 AM
byteme's Avatar
byteme
Default p0351 error cleared now code not returning
01 Dodge 1500 360
sudden no start was getting 0351 error .This happened before and it was the coil driver in the pcm , pulled the pcm can not smell anything burnt like last time Cleared teh code cranked the hell out of it and code does not return ??? still no start and now no codes..
Old Mar 26, 2018 | 03:41 PM
Are you getting spark? Getting power to the coil?
Old Mar 26, 2018 | 05:47 PM
byteme's Avatar
byteme
not as far as i can see left my tools in the wifes jeep so test lite or meter You would think if the coil driver or the crank sensor wit it would still store a code ???
Old Mar 26, 2018 | 05:50 PM
Depends on what the PCM thinks is wrong. Not sure it can tell that the coil driver has failed or not..... You can lift the wire off the coil a bit, and have someone else crank the motor, to see if you have spark..... Careful though, you make a pretty good ground path as well.... and that HURTS.
Old Mar 28, 2018 | 10:22 AM
byteme's Avatar
byteme
no theres no spark i tested the gray wire into terminal 1 on the coil and there is no trigger signal Im going to check the other wire ,Is there a pin out for the PCM so i can check the coil driver
Old Mar 28, 2018 | 10:52 AM
true blue's Avatar
true blue
Have you checked the wiring, plug to...and crank position sensor yet? The crank sensor is the union boss that tells the ECM you wanna do something involving the engine and as a bonus, it gives the coil a reason to fire.
Old Mar 28, 2018 | 03:12 PM
Does the fuel pump run while cranking?
