How to remove 02 sensor at catalytic converter?
Old Apr 6, 2018 | 09:42 PM
not2techie's Avatar
not2techie
Originally Posted by Ramman18
Yeah, pipe wrench may help. Another trick is to run it til the exhaust warms up but you said its dead right?
Correct. But I took the battery out today, hooked it up to my charger, and that appears to have died from driving the truck last time. The truck might start now again, with this battery fully charged.
Would a failing alternator and/or dead battery be enough to make the engine die at highway speed? The alternator gauge indicates 12 to 14, pretty consistently.
Old Apr 6, 2018 | 09:45 PM
not2techie's Avatar
not2techie
Originally Posted by jkeaton
The connector is farther up the wire. Not where you are looking.
I looked only very quickly, those wires go up and merge in with a bunch of other wires, which have the plastic guards around everything. Is there an actual connector hidden up in there somewhere?
Old Apr 6, 2018 | 09:54 PM
Yes. There is.
Old Apr 6, 2018 | 10:07 PM
Michael92's Avatar
Michael92
Either/both of those would definently be enough to make it die at highway speed. Say it being your battery.. then there's nothing to supply electrical current to sensors and plugs and what not. Then you got the alternator, witch it's main purpose is to keep the battery at a full charge while running so everything has juice.
The plug in for the 02 sensor is attached to the top off the transmission. There suppose to slide off the clip to the transmission, then you can push in the clip and pull apart. There a pain in the butt.
to me it sounds like your main issue is battery or alternator. As an 02 wouldn't make your truck not start. But a dead battery would. A bad alternator would let it run for a bit on a good battery till the battery is dead. If you have a volt meter check it. Should be 12v (or more) on battery terminals before cranking, while cranking it shouldn't dip below 11 min, and while running it should be at least 13.
Old Apr 6, 2018 | 10:08 PM
not2techie's Avatar
not2techie
Yeah, above the trans, almost at the top. That's a fun reach.......
It sounds like, I need to start from the sensor, and trace them up to above the tranny, to find an actual connector? Can it be found from starting at the top side? I'm guessing the engine will be in the way of that approach. :-(
Old Apr 6, 2018 | 10:10 PM
Michael92's Avatar
Michael92
Yes. Basically take your hand along the wire till you feel the connector. It's only about 12-18 inches of wire till the connector. You'll need both hands to pull apart. You have to be on the ice to do it lol
Old Apr 6, 2018 | 10:11 PM
Michael92's Avatar
Michael92
There's a connector tab also, push it in then the clip comes apart. Try sticking your head up in there if possible.
Old Apr 6, 2018 | 10:19 PM
not2techie's Avatar
not2techie
Very helpful, Thank you! The theory I was working on, is that the o2 sensor is not faulty, but rather it is working and telling me that the cat is clogged, and hence, perhaps the reason the engine will not run. However at this point, it would not surprise me if both things are (or all 3) are at fault. I was leaning towards the cat problems due to the plenum thread that is stickied. Checking the plenum is on my 'to-do' list.
Sounds like I better hurry up on finding that connector, before the ice melts!
LoL
Old Apr 6, 2018 | 10:43 PM
Shadow_Death's Avatar
Shadow_Death
If you suspect a cat issue then pop both front O2 sensors out and try to fire it up. If it starts with the o2 sensors out of their respective bungs then the cat(s) is/are clogged.
This is how I determined that my exhaust was toast.
Old Apr 7, 2018 | 04:34 AM
Michael92's Avatar
Michael92
Sorry, forgot about a clogged cat problem. I was half asleep responding last night lol works been demanding. But no problem. If all else fails hook up a scanner and see if you have any check engine. That I'd do after a new battery, and testing the alternator to rule it out.
DONT FORGET, most auto parts store will test both of those components for you (for free) if you take them out and take them to them. Battery and alternator.
Let us know how it goes.
