Control arm bushings
Old Apr 6, 2018 | 04:31 PM
Lyle Kruse's Avatar
Lyle Kruse
Default Control arm bushings
I'm new to the forum, I have a 1999 Ram 1500 4x4 with the 5.9 Magnum. I have been slowly replacing everything in the front end. Anyways, I took on the task of replacing the control arm bushings, and bought the Energy Suspension poly bushings. Well, I accidentally bought the set for the 2WD model (5.3124R) instead of the ones for the 4WD model (5.3131G). The instructions for the 2WD set say to re-use the outer metal shells for the lower control arms, but not for the upper ones. So I cut the upper ones out. My question is, where can I find replacement outer metal shells? Or do I have to buy new control arms?
Thanks
Old Apr 6, 2018 | 04:32 PM
I don't know that the outer shells are sold separately. Do they come on the stock replacement bushings?
Old Apr 6, 2018 | 05:52 PM
AtomicDog's Avatar
AtomicDog
Easiest bet might be to pickup a couple of replacement control arms at a pick and pay salvage lot.
