sudden 46 re problem fluid level went high
Old Apr 20, 2018 | 02:08 PM
Nick Bain's Avatar
Nick Bain
update, road tested today and found it would not go into OD at all, I also should also point out it has been spotty going fully into OD since I bought it. Rpms not dropping fully but most of the way. for example it should be at 2k at 70 sometimes it will bounce around 2250 and up to 2500 (during which it sounds lightly rough like its not fully enganged), but definitely not 3k which is when it is completely out of OD. Also it did not like reverse one bit.
Still working on building up to drop the pan and looks like ill be getting into the valve body as well. based on what I am reading in the service manual.
Old Aug 30, 2018 | 06:42 PM
Nick Bain's Avatar
Nick Bain
figured out what was wrong, is it possible for OD planetary to shred in 2 years? Also the spring is flattened so did not need a press to take it apart.
Old Aug 30, 2018 | 07:08 PM
That got REALLY hot for the spring to deform like that. Rather curious what happened there......
Old Aug 30, 2018 | 11:03 PM
Nick Bain's Avatar
Nick Bain
the one thing I can assume is that they rebuilt it and did not replace these parts or look at it at all. the lady i bought it from said she brought it in for a 1-2 shift issue so is it possible they left the overdrive alone? still trying to find that one out. everything else in the main case looks immaculate. Also it is apparent they were towing something as the truck has a trailer brake controller on it. oh and it has 200k miles on it.
Old Aug 31, 2018 | 04:08 AM
Michael92's Avatar
Michael92
If i remember rite the overdrive band and drum are at the very bottom, or back, of the tranny with a pressure spring (closest to the Transfer case). Its VERY possible that its been rebuilt with out the OD internals being touched or replaced. Since at the time it probably didnt give them problems. Either that, or they did rebuilt it and finally something gave way. If you where to take that part to a tranny shop and ask them whats the deal they may be able to throw some ideas at you as to what actually happend in there.
like hey you said, looks like something got hot and melted your disk or whatever under the spring. Does the part that those od gears ride on F'd up to?
Old Aug 31, 2018 | 04:12 AM
Michael92's Avatar
Michael92
Any debris in the trans, lines or coolers? To me it looks like crap got stuck in there, locked the gears and as it spun chewed teeth off.
how does the ring gear look that the planetarys ride on?
Old Aug 31, 2018 | 05:45 AM
Nick Bain's Avatar
Nick Bain
the ring gear is fine but the sun gear is trashed and roller bearing spring thingy is toast with wear on the sprag. the output shaft surface that the roller bearing rides on has some wear as well. The friction plates have some wear closest to the planetary/ spring where the heat was but not totally shot. pics to come
Old Oct 16, 2018 | 01:45 PM
Nick Bain's Avatar
Nick Bain
Well I finished it up and its back on the road. Found a whole OD gear unit fully assembled with good parts (hopefully) off eBay for 200 included new frictions that go on the outside, all new solenoid/sensor/filter kit 175, sonnax zip kit 150?, snap ring, a few case gaskets, TC 180. About 100 in new tools, and something else I feel like forgetting cause I thought I spent 1,000. Had to top the fluid off twice once it all worked in. Before I took it out I did pump out the oil while it was in gear and I blew out the cooler lines with air and used one of those self propelled solvent cans the shop air again. I did not see any particles anywhere. It seemed to be all trapped behind the filter in the pan. There was so much that the magnet could not hold it all. Trans shop thought there was not enough fluid getting to the OD unit. When I filled it with new fluid I left the return line off so it would pump out any remaining bad stuff. It gushed out clear (red) in a couple seconds and had great flow so I think the check valve is fine. This happened in park so the sonnax is working. It was shifting kind of weird at first and would not start off in 1st. so once I got all the fluid in I decided to look into the TV cable which I was surprised how touchy it was I went 1/4 tighter cause I thought it was super slack and I was shifting like a race car so I dialed it back 1/8'' and it shifted like brand new. who knows how long it was like that? or maybe it was something I changed when I went through the settings per the sonnax kit can't recall. Anyways I think I own the best 46re now and I think its ready to go up a mountain.
Old Oct 16, 2018 | 03:05 PM
Awesome.
