Transfer case questions
Old Apr 20, 2018 | 11:20 PM
dirtynewf's Avatar
dirtynewf
Default Transfer case questions
Hello all,
So my transfer case 231d on a 2001 5.2 with a manual tranny is shot wont send power to my front driveshaft and in order to roll i had to drop the front driveshaft and plug the front splined hole i think the bearing on that shaft was shot? i dunno either way i need a new t case or to rebuild it.I am no professional mechanic but im not afraid to dig in and get nasty with my girl if i need to. so what i've gathered is the tcase off a auto and manual have the same input and output shafts spline counts but are they compatible? because i found one off an auto for $200 but cant find a used one off a stick for the life of me. So bestow some knowledge upon me please
i also use this truck as a dd and i need the 4x4 to work because i live in CANADA eh and i use it to plow snow
p.s truck has 265000 kms and runs like a top
thanks
Old Apr 21, 2018 | 08:23 AM
Yep, same t-case. There are some differences in the input hub though, the manual trans version is a bit longer. It might work just fine, but, to be safe, I would be real tempted to swap parts around, and put in the correct input hub.
There really isn't that much to the transfer case. If you have something else to drive for a bit, pulling yours, tearing it down, and seeing just what is screwed up isn't too bad of a job.
Old Apr 21, 2018 | 02:44 PM
dirtynewf's Avatar
dirtynewf
Thanks man much appreciated
