98 Transfer case on a 96?
Old Apr 21, 2018 | 04:44 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default 98 Transfer case on a 96?
Will a 98-01 Transfer case fit a 96 and work? Same engine so the shafts should be the same. Only reason I'm asking is I'm putting a full center console out of a 4th gen ram in my truck and it has the "older" shift pattern where you have to push to the side to get to N and 4L. Where the newer transfer cases in one straight line. Thanks for the input guys! Sorry for all the weird questions (I think it will personally but want to be sure) but I want they custom interior!
Old Apr 21, 2018 | 08:19 AM
Its not so much the shift pattern that is the issue, its the lack of the VSS on the tailhousing that will be a problem. 98 didn't have one..... 97 and older need it for the speedometer, etc.
Old Apr 21, 2018 | 02:22 PM
MoparFanatic21
Could you transfer the tail housing from the 96 tcase to the 98?
Old Apr 21, 2018 | 03:48 PM
I don't think the drive gear is on the output shaft of the newer t-case either. You *might* be able to put one on, if the splines are there, otherwise, I think you would need to swap that shaft as well.
Old Apr 23, 2018 | 02:36 AM
MoparFanatic21
Ah not to hard. I always get the "mut" trucks. But for $400 I can't complain. I am just seeing what wiring is needed to use the rest speed sensor instead of the one on the trans.
Old Apr 23, 2018 | 08:11 AM
I don't know if there is a difference in return signal from the two sensors.... but, as the tone ring diameters will be QUITE different, I doubt they are the same.....
Old Apr 23, 2018 | 02:49 PM
MoparFanatic21
Im just worried that when I switch to the new dash and fuse box from an 01 that the speedo won't work.
Old Apr 24, 2018 | 09:13 AM
frankie_b_jr's Avatar
frankie_b_jr
I used this box from Dakota Digital to make the speedo work in my 97 cab and 98 undercarriage. It should work for what you're trying also.
http://www.dakotadigital.com/index.c...rod/prd126.htm
It also makes it nice for changing tire sizes. Push a button and set it where it should be.
Old Apr 25, 2018 | 12:21 AM
MoparFanatic21
Thanks so much my truck is an 01 2500 with a complete 96 drivetrain and cab just trying to make it original again. Thank you! Thank you! Thank you! Lol
