Headlight Switch Issues
Old May 29, 2018 | 01:02 AM
  #21
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 2bit
Yes, I'd look for a bad ground.
https://www.powerprobe.com/ppkit03
If you can afford it, this thing is awesome!
Bad ground??
I have one of them. I tested everything honestly. Grounds, power wire, shorts, nothing is found wrong.
Old May 29, 2018 | 10:06 AM
  #22
2bit's Avatar
2bit
So now we're back to needing an ice cold case of road sausage while we discuss this.
Old May 29, 2018 | 10:13 AM
  #23
2bit's Avatar
2bit
Power Probe has a tech line you can call. I'd try that. 800/ 655-3585
Old May 29, 2018 | 11:49 AM
  #24
MoparFanatic21
Basically I know it's something stupid
i tried that basically useless. It's like the rod isn't in the whole way or something
Old Jun 19, 2018 | 09:39 PM
  #25
MoparFanatic21
This plug right here behind the gauge cluster and I had to pull the dash to fix the burnt wires and wiring mess the PO did. This fixed my problem.
Old Jun 19, 2018 | 09:42 PM
  #26
Awesome.
Old Jun 19, 2018 | 10:25 PM
  #27
MoparFanatic21
Awesome.
I know also you were right about the bulb causing my park lights to gladf with the left turn signal. That's how the plug was I ran all new wires and got rid of that inline tap (blue thing on the red wire)
Old Jun 20, 2018 | 05:20 PM
  #28
2bit's Avatar
2bit
Glad you figured it out. It's hard to find problems caused by other peoples stupidity. That plug isn't where you'd look for the problem you had.
Old Jun 20, 2018 | 09:30 PM
  #29
MoparFanatic21
Well thought I had it fixed, it isn't. It's in that plug (Joint Connector A) because when I jump pin #10 to pin #4 it causes the problem. If I remove the factory way if connecting all the pins it won't do the problem just nothing dims when park lights are engaged.
Old Feb 21, 2019 | 09:09 AM
  #30
drewbaker91's Avatar
drewbaker91
I have the exact same issue. Did you just remove the factory connections and put on a different connector?
