Front end Grinding while turning
Old Apr 28, 2018 | 03:27 PM
cjames1173's Avatar
cjames1173
Exclamation Front end Grinding while turning
HEy Guys, Y;all helped me with my Lass problem so here goes... In my 2000 RAM 1500 w/ 5.2 318 V8 2WD w/ 219k miles, I get a grinding sound in the front end at low speeds ONLY when turning sharply. This happens especially when I'm towing, most severely while backing/turning. Ball joints have 2k miles on them, tie rods 50k max, I've inspected my brake components to the best of my advanced-amateur abilities. My pads have roughly 50% life in them, rotors are like-new (visually). This problem has gotten worse over the course of 8 months with no success at finding the problem, any ideas fellas?
Old Apr 28, 2018 | 05:43 PM
Jack it up, and spin the tires by hand, sounds like you have a bearing going out.
Old Apr 28, 2018 | 08:59 PM
true blue's Avatar
true blue
Steering pump going out, or maybe steering box? What size tires do you have?
Old Apr 30, 2018 | 03:57 PM
cjames1173's Avatar
cjames1173
Default Grinding while Turning
My Tire size is standard 245/75/16. I'm pretty sure I've determined that its my front passenger hub assembly. I jacked it up and there was play L-R and U-D. Considering I replaced ball joints/tie rods this year i think that's it. I checked out the replacement costs and can't decide between the Mopar wheel hub assembly for $309 with a 3yr Warranty or the Dorman (which I've never heard of) for half the Mopar price with a limited lifetime warranty. I don't want to repeat this repair anytime soon, lifetime warranty or not. What do y'al think? Thank you for your replies HeyYou and true blue!
Old May 1, 2018 | 07:48 AM
The mopar unit is overpriced, dorman doesn't have the best reputation for longevity...... There are a couple other folks out there that also make them, (timkin, et al.) that have a MUCH better reputation.
Old May 1, 2018 | 09:54 AM
true blue's Avatar
true blue
U mite wanna consider a junkyard unit if money is tite. If ya got the tools, you can pop her off with a few wrenches, sockets n a pickle bar of the rite size.
