Where's your fog light switch mounted?
Old Dec 3, 2005 | 02:56 AM
Two60s98's Avatar
Two60s98
Default Where's your fog light switch mounted?
For those without the factory fog light switch up with the headlamp one...
Just wondering where your aftermarket switches are mounted. Not alot of places avaialable on the Ram dash bezel.
I'd like to get the factory headlamp switch that has the foglamp built in eventually. The previous owner of our 98 Ram loosely placed the fog lamp switch down beside the steering column. I'd like to mount it in a better location. It's small enough to mount to the right of the headlamp switch.
Old Dec 3, 2005 | 04:30 AM
2kramquad's Avatar
2kramquad
Default RE: Where's your fog light switch mounted?
It's nothing to brag about, but it works. It came with a pre-wired relay kit that I got at Advance Auto, and it's mounted with double sided tape.
[IMG]local://upfiles/5732/30CD4CE064824923878B89973D421414.jpg[/IMG]
Old Dec 3, 2005 | 04:54 AM
Fubba's Avatar
Fubba
Mine is beside the overdrive switch.
Old Dec 3, 2005 | 12:49 PM
4DrMopar's Avatar
4DrMopar
mines mounted in the UPPER console, liek where yer sunglasses go...
Old Dec 3, 2005 | 03:52 PM
Dodgeramman's Avatar
Dodgeramman
Next to the OD switch.
Old Dec 3, 2005 | 05:03 PM
Two60s98's Avatar
Two60s98
Hmm.. my OD switch is in the shifter stick. Kinda hard to mount one there. You guys must have manuals. Where's your switch?
2kRamQuad - Mine's alot like yours, except it's right at the steering column opening, and the tape doesn't stick any more.
Old Dec 3, 2005 | 09:20 PM
Dodgeramman
On the dash above the radio, next to the cup holder.
[IMG]local://upfiles/23455/DA4D64365DA0487D8740777CF9985F4D.jpg[/IMG]
Old Dec 4, 2005 | 10:01 AM
zeekxxx's Avatar
zeekxxx
oooo switches. I love switches... heres mine.... Each one was lovingly added as not to look too tacky with exposed wires and poor cutting.
This one is hard to see but look on dash right behind turn signal. This was the first to be put in for fog lights. Involved removing the dash trim.
This was for my Lightforce lights and my train horns. Involved tearing the whole shifter assembly apart to do right.
Extra power switch mounted under the 12v outlet. Tore out the dash to wire correctly.
The last one for now is running my new fog lights that I put in a month ago. under the 4x4 gear selector. Tore the center shifter console out again.
For the new guys I got a nice write up on the 5th or 6th page about switches.
check it out - http://www.ronbarthelt.com/ram1a.html
Old Dec 5, 2005 | 02:44 AM
Two60s98's Avatar
Two60s98
You the man Zeek.
