Oil Pump Screen
Old May 18, 2018 | 12:53 AM
Ramman18's Avatar
Ramman18
Haha, well let the new owner know how to find dodgeforum.com and we'll help him with the issue, lol!!!
Old May 18, 2018 | 10:05 AM
V65Ozzie's Avatar
V65Ozzie
As was said before, go ahead and install a new oil pump. Pack it with grease before you install it. Then on initial startup, pull the coil wire until you show oil pressure while cranking, then hookup the coil wire and fire it up. A new sender is a good idea, I like to remove the old one, then crank engine to clear any crud out of the port before I install a new one.
My truck, when I got it, always had low oil pressure, no noises. I've made quite a few long distance highway runs, done about 4 oil changes. I run about 6k between changes. Now it stays rock solid at 40psi at idle. Haven't changed any parts.. Gotta add a quart every now and again....dang intake....
Old May 18, 2018 | 10:41 AM
Ramman18's Avatar
Ramman18
Originally Posted by v65ozzie
as was said before, go ahead and install a new oil pump. pack it with grease before you install it. ...
whattt????
Old May 18, 2018 | 11:44 AM
V65Ozzie's Avatar
V65Ozzie
Originally Posted by Ramman18
whattt????
Old trick, helps the pump to prime. Some people just flood them with oil, that works too... Never spin an oil pump dry.
Old May 18, 2018 | 02:14 PM
Indeed. I usually use white lithium grease. Not as heavy as the wheel bearing stuff. Easier to pump. (and works just as well.)
Old May 18, 2018 | 03:53 PM
true blue's Avatar
true blue
When was the last time anyone here reprimed their oil pump after draining their oil? You folks realize every time you change your oil, you drain the oil from the oil pan, effectively draining the oil pump...rite?!?!?
Old May 18, 2018 | 03:56 PM
That's true, but, when you REMOVE the oil pump, there is no oil above it either..... it doesn't hurt anything to prime it, and it is required when installing a new one.
Old May 21, 2018 | 04:47 PM
V65Ozzie's Avatar
V65Ozzie
Dang, you beat me to it........ I used to work on hi-po motorcycle engines. I've seen some nasty oil pumps.......
It's amazing how much abuse an oil pump will take until it fails. But when it does.............BOOM!!
Old May 22, 2018 | 07:23 PM
Jaw91097's Avatar
Jaw91097
The truck blew up over the weekend on my way to the gas station. Hole straight out of the oil pan.
Old May 22, 2018 | 07:43 PM
New motor time?
