96 Ram crank no start
Old May 19, 2018 | 06:27 PM
Bwd291's Avatar
Bwd291
Default 96 Ram crank no start
I have a 96 Ram 1500 5.9L that has no spark and no injector pulse. I have replaced crankshaft sensor, pickup coil, ignition coil, NSS. I have fuel and fuel pressure. It started after I replaced my TCC harness. I jacked it up, replaced the harness and it would not start after that. My gearshift is also hard to pull into gear (automatic transmission) and the truck will only crank on neutral now. At first it would crank in either park or neutral, but not after trying to adjust the shift linkage.
Old May 19, 2018 | 10:12 PM
Need to readjust the shift linkage.....
Unplug the rear O2 sensor, see if the truck will start.
