Sport Headlight Conversion
Old May 28, 2018 | 03:39 PM
dacker's Avatar
dacker
Default Sport Headlight Conversion
About ready to scream!!!!! I have researched until I am Sick. Will someone tell me will these lights (either set) work if I make this harness on my 98 ram 3500 4x4
https://www.ebay.com/itm/Spyder-Auto...item3d5ce24c5c
https://www.ebay.com/itm/99-01-Dodge...del%3ARam+1500
https://mopar1973man.com/topic/2409-...ht-conversion/
Old May 28, 2018 | 03:54 PM
If it's a late production 98, they should fit just fine.
Old May 28, 2018 | 04:23 PM
dacker's Avatar
dacker
Hey brotha I started to just PM you but figured I'd give you a break from all the questions I asked the last time and still gone have to hit you up when I do the shift kit we talked about. So will the vin # tell you if its a late enough model?
Old May 28, 2018 | 05:19 PM
Date of manufacture should be on the sticker inside the drivers door frame. I am not sure when the "98.5" models came out.... but, the info should be out there somewhere.
Old May 28, 2018 | 05:36 PM
dacker's Avatar
dacker
My luck I will be right on the bubble lol
Old May 28, 2018 | 06:08 PM
dacker's Avatar
dacker
The only thing I keep finding is the reference between the 12v and 24v on the diesel which mine is a v10 gasser so that doesnt help.... I did see that if the quad cabs had doors that opened it may be 98.5 but can not confirm it.... Still searching away though
Old May 28, 2018 | 07:29 PM
You should have the 98.5, so, the sport headlight buckets should bolt right in.
Old May 28, 2018 | 08:18 PM
dacker's Avatar
dacker
Perfect thank you again my friend.... Just FYI I started that other thread to try and keep from bugging you too much... I would like an opinion on whether the smoke or clear would look better on my rig.
Old May 28, 2018 | 09:15 PM
With the white and chrome, I would be tempted to stick with the clear, but, its your truck, get what ya like.
Old May 28, 2018 | 09:31 PM
dacker's Avatar
dacker
That's kind of the way I was leaning so thanks for helping me confirm it my friend!!!
