99 ram inner clip yoke to flange style
Old May 30, 2018 | 10:21 PM
Goodoldgreenram's Avatar
Goodoldgreenram
Default 99 ram inner clip yoke to flange style
Hello this is my first post.
I have a 99 ram 1500 and looking to upgrade the original rear pinion yoke from the inner clip style to the 01 flange style.
I have pulled a yoke and drive shaft from another truck it is also a 29 spline as I have read the 99 Chrysler 9.25 is curious if anyone has done this yet.
Also anyone use the crush Sleeve eliminator kits before sorry if this is already posted before.
Thank you.
Old May 31, 2018 | 07:26 AM
Are you having issues with your current setup?
Should be a fairly straightforward swap. Never tried the crush sleeve eliminators, but, seems like a good idea....... just tedious on the initial setup.
Old May 31, 2018 | 09:57 AM
Goodoldgreenram
Default Yoke
Really want to get rid of the c clip yoke and go to flange style or companion Style I don’t mind the tedious setup
Old Jun 1, 2018 | 07:55 AM
I think that flange, and the end of the driveshaft, were the only changes..... should be a pretty straightforward swap.
Old Jun 1, 2018 | 02:41 PM
Goodoldgreenram
Default Yoke flange
Sweet yeah I counted the splines on the flange yoke it is also 29 spline I got the whole rear and yoke from a same wheelbase truck time to upgrade thank you for the help.
