Ignition control module for 94 Ram 2500 8.0L v10....
Old Jun 1, 2018 | 02:51 PM
arabstar1982's Avatar
arabstar1982
Default Ignition control module for 94 Ram 2500 8.0L v10....
Does anyone, by any chance or act of God, have a lead on an ignition control module for a 1994 Dodge Ram 2500 V10 8.0L, part # 56027879???? I know it is way late that I am coming into this problem, however, here I am - truck in good shape and it is parked, almost seeming like permanently unless I can find one of this little devils for it. I have discovered that Dodge stopped making these things in 1997 and only the 94 95 96 v10 had the module. I have cylinders 4 and 7 not firing and this little devil (from what I have discovered in my searches) has been known to cause 4/7 and 5/10 cylinders on coil packs to not fire when they go bad. Any leads greatly appreciated!!!
Old Jun 2, 2018 | 10:10 AM
I think the common solution for your issue is to change the wiring to use the 96 and up coil packs. There is a thread about that around here somewhere.
Aside from that, Ebay, or the used market are pretty much your only options.
Old Jun 3, 2018 | 01:54 AM
arabstar1982
I thought the 96 still used the ignition module and it was 97 that didnt. I have looked into that option and the transmissions wont match up because in 96 they went to RE transmissions and I have the RH still. Not sure how that would affect the computer operations. Do you happen to know if all else would be a plug and play (all sensors in same spot on the newer year engine, etc), or will there need to be some cutting and splicing involved? Thanks!
Old Jun 3, 2018 | 01:56 AM
arabstar1982
I do know the 96 computer is different than mine, because when we were looking at ECMs, only 94 and 95 are compatible. I am guessing because they changed the transmissions in 96, but am not sure...
Old Jun 3, 2018 | 09:22 AM
All you would be changing would be the coil packs, and their electrical connectors. Everything else stays the same.
Old Jun 8, 2018 | 04:16 PM
V65Ozzie's Avatar
V65Ozzie
Have you tried these guys?
https://www.fs1inc.com
Just ordered a computer for a Taurus X (dreaded coil misfire-trashed computer) And a Jeep.
