Need Help on HVAC
Old Jun 6, 2018 | 05:37 PM
faftgs's Avatar
faftgs
Default Need Help on HVAC
All,
I have a 1997 Dodge2500 with the Cummins and have a HVAC issue that I hear is common. The truck only has approx. 68K miles. A few weeks ago the HVAC was working fine, then the following week it would blow through defrost vents until the engine was under some load and then return to the defrost vents when clutch was depressed or at idle. Finally last week, it only blows through the defrost, no change at all. Is this a vacuum pump issue?
Old Jun 6, 2018 | 06:29 PM
It's a vacuum issue at any rate. Sounds more like you have a leak somewhere.
