360 Motor markings 360AB what is"AB"?
Old 06-11-2018, 09:07 PM
nicraage's Avatar
nicraage
nicraage is offline
Default 360 Motor markings 360AB what is"AB"?
Does anyone know what the "AB" means after the 360 on the casting marks? It says 360AB. It could be 360A8. The B or 8 looks more like squares.
I want to know if I will be able to drop this in my 2001 ram. Thanks.
Old 06-12-2018, 02:38 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
You can just need to use the intake (center head for the older guys) from the 01 motor
Old 06-12-2018, 08:45 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Should be able to. Do you know what the motor came out of?
Old 06-12-2018, 09:38 AM
nicraage's Avatar
nicraage
nicraage is offline
MoparFanatic21, thanks. I will eventually be using a hughes.
AtomicDog, I assume a van, because the air intake cover looked quite strange. However I do not know the year
Old 06-12-2018, 06:44 PM
AtomicDog's Avatar
AtomicDog
I'd check the oil pan to make sure it will work in the truck chassis (or swap it from the old motor, along with the pickup) and check the motor mounts.
Old 06-12-2018, 07:21 PM
Moparite's Avatar
Moparite
Moparite is offline
The 360 magnum motors ran from 1993–2003 (casting # 53020006) If you don't have that # before the "360" it's an LA motor.
Old 06-13-2018, 01:20 PM
nicraage's Avatar
nicraage
nicraage is offline
Thanks everyone. The exhaust manifold, and air intake got swapped . The oil pan cleared fine. The motor got dropped in last night. and started up. I think we kept the motor mounts from the Van on. They looked stronger, and were 1 solid piece.
Quick Reply: 360 Motor markings 360AB what is"AB"?
