96 1500 won't start.
Old Jun 24, 2018 | 06:17 PM
Mike May's Avatar
Mike May
Default 96 1500 won't start.
96 won't start. Injectors and fuel pump stay on after it died. Now when the key is set to on. This pump comes on and the injectors start pulsing. I have changed the crank sesnsor, the AIC, TPS, and the distributor ignition pickup. Still nothing. Any help would be appreciated. Thanks, Mike
Old Jun 24, 2018 | 08:57 PM
Sounds like the pcm has failed..... try disconnecting the battery 30 minutes or so.
Old Jun 24, 2018 | 09:30 PM
Mike May's Avatar
Mike May
Default Thanks, I'll give that a shot
E
Got me stumped. I sppappreci the input
Old Jul 14, 2021 | 10:37 AM
true blue's Avatar
true blue
Have you tried swapping the ASD relay with another relay in the power distribution box under the hood yet? I know those ASD circuits can become problematic with time.
Old Jul 14, 2021 | 10:58 AM
master tech's Avatar
master tech
Site Moderator & Tech
Do you have spark at the plugs? And would remove a spark plug is it soaked with fuel?
