46re upgrades
Old Jul 3, 2018 | 08:22 AM
TarheelDodge's Avatar
TarheelDodge
Default 46re upgrades
I'm looking for advice for upgrading a 46re in a 1999 ram 1500 with a 5.2. Basically what shift kit or other parts improve shifting or longevity. Thanks for the help, Greg
Old Jul 3, 2018 | 04:15 PM
Check out page 6 of montec's transmission corner thread. He has a list of recommended parts in there for a member that regularly towed a 7000 pound trailer.
Rumor has it, that the internals from the 47 or 48RE will fit into the 46 case as well...... That could be interesting.....
Old Jul 3, 2018 | 06:11 PM
Moparite's Avatar
Moparite
It's not rumor, Everything but one of the drums i believe. I read a detailed article on it somewhere. The only reason you can't use it the 46RE case is a bit smaller and the drum will hit it. It's pretty much what PATC does in the mega viper trans but instead of 47/8 parts they sell their own upgraded/billet parts.
Old Jul 3, 2018 | 09:59 PM
Hhhhmmm.. Interesting. It's not usually the drums that fail though, is it? Isn't it generally clutches/planetary gearsets that give up?
Old Jul 3, 2018 | 11:19 PM
2bit's Avatar
2bit
The bigger drum would hold bigger/more clutch plates, wouldn't it?
Old Jul 4, 2018 | 09:18 AM
One of the mods PATC does is more clutches. I think they use a thinner piston plate to account for the additional room required. Not sure if the 47/48 drum is larger diameter, thicker metal, or what.
