water pump
Old Jul 5, 2018 | 07:45 PM
tyler nelson's Avatar
tyler nelson
Default water pump
got a 99 v10 2500.it looks like the water pump is leaking.its very hard to see up there but does it have a bolt that is a drain?it looks as though i have a bolt missing and its leaking out of the hole
Old Jul 5, 2018 | 08:47 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
A water pump has a weep hole on the bottom that leaks when the bearing in the pump is going out. If it's leaking there you need a new pump
Old Jul 5, 2018 | 08:55 PM
That's likely the weep hole for the water pump. That means an internal seal is failing, and it's time for replacement. All of the bolts on the water pump go into the timing cover horizontally, no vertical bolts.
