Blown Plenum After the Repair
Old Jul 28, 2018 | 02:26 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Default Blown Plenum After the Repair
How much vacuum is the 5.9 suppose to make at idle? My truck loses vacuum under moderate acceleration and at 55 going up a slight grade the cruise control can't hold the speed. I just repaired the plenum and timing chain with an aluminum plate and Cloyes double roller. I checked for vacuum leaks, there is none. Put a guage on the manifold and I make 18 inhg at idle. The truck seems to sightly struggle up hills. No oil on the plate yet, but it's only been a very hundred miles. Any opinions or suggestions?
Old Jul 28, 2018 | 08:02 AM
Moparite's Avatar
Moparite
Do you have the wild vent issue? There are two check valves one right next to the intake and another up where the vac reservoir is. It's possible the one next to the intake is bad or the vac line going to the cruse control actuator is craked. This is a major know area where they crack and leak. You will get the highest vac reading when the throttle is closed.
Old Jul 28, 2018 | 08:14 AM
fj5gtx's Avatar
fj5gtx
When I was working on the 4x4 actuator, I was seeing about 17.5 inches of vac. Not sure where they tap that on the engine. But there is a reference point for you. What is your idle rpm?
Old Jul 28, 2018 | 01:50 PM
MoparFanatic21
yes but only a little after the vacuum drops. I even have the updated check valve
About 500-650 can't really tell exactly but there's according to my scan tool. 17.5 I'm not getting that
Old Jul 29, 2018 | 05:20 PM
MoparFanatic21
Checked the intake with the throttle body off no oil in there that I can see but I'm wondering if I tightened the manifold bolts tight enough
Old Jul 29, 2018 | 05:32 PM
fj5gtx's Avatar
fj5gtx
Why do you think its a vacuum problem, not quite following the logic...
Old Jul 29, 2018 | 06:20 PM
Disable ALL vacuum accessories. Pull the hoses, plug the ports. (except for one for your gauge.) See what manifold vacuum looks like that way.
Old Jul 29, 2018 | 06:25 PM
MoparFanatic21
I did that, got 17.5 exactly. Is that what it's supposed to make?
Old Jul 29, 2018 | 06:26 PM
Hhhh...... I think spec is 18-20... So, you are at least close. Probably wouldn't hurt to re-torque the intake bolts.
Old Jul 29, 2018 | 11:46 PM
MoparFanatic21
I didn't use a torque wrench as you need an extension (which messes with torque) and want doing the math as my mind is still on the brakes.
