ignition coil wiring
Old Jul 30, 2018 | 03:23 PM
j_politz's Avatar
j_politz
Default ignition coil wiring
I've got a misfire on the #1 coil on a 4.7 2006 Dakota, swapped coil from one plug to another, issue stayed @ #1.
There are two wires going into coil, one is the power and it's got power coming into coil, where does other wire connect? to PCM ??
Old Jul 30, 2018 | 03:29 PM
Other wire will run to the pcm. PCM controls the ground to fire the coil. You really need to be in the Dakota section though.
