TPS reading
Old Aug 10, 2018 | 03:49 PM
  #21
MedicNathan's Avatar
MedicNathan
TB and IAC thouroughly cleaned. No more CEL. It's running better, but still no power. Fuel trim is no longer dropping below -25%. So I'm basically down to MAP sensor right? Image attached is idle slowly up to full throttle
Old Aug 10, 2018 | 04:58 PM
  #22
What does the map graph look like? Start at idle, and slowly lean into the gas. (in park, or neutral....)
Old Aug 10, 2018 | 07:15 PM
  #23
MedicNathan
Kinda like this
Old Aug 10, 2018 | 09:20 PM
  #24
And that is slowly pressing the gas?????? That's just wrong. Either the sensor is bad, or the little rubber elbow leaks.
Old Aug 10, 2018 | 11:37 PM
  #25
MedicNathan
Rubber elbow was leaking. Replaced and I'm getting a much smoother change on the MAP.
So the nice part is the engine will now start and run reliably. I still have no power and still running incredibly lean.
Old Aug 11, 2018 | 09:19 AM
  #26
I would be tempted to hook a gauge to a vacuum port on the manifold, and compare those readings to what the map is reporting.
