Can anyone share photos of a factory rear sway bar installed on a 2nd gen 2500 truck?
Old 08-19-2018, 10:04 PM
AtomicDog's Avatar
AtomicDog
AtomicDog is offline
Default Can anyone share photos of a factory rear sway bar installed on a 2nd gen 2500 truck?
I just picked up a used factory rear sway bar (came off a 1998 Ram 2500 truck) that connects to the shock mounts of my Dana 60 rear. I'd like to better understand how the sway bar links off the front of the bar connect to the truck. My used rear sway bar did not come with the sway bar links, but they appear available at parts stores. Does anyone have any photos or diagrams that they can share that show the rear sway bar link connections to the truck?
Old 08-20-2018, 01:43 AM
primem's Avatar
primem
primem is offline
this help?
Old 08-20-2018, 09:54 AM
AtomicDog's Avatar
AtomicDog
That's perfect. Where did you find this photo? Now, I just need to find the two frame mounts for the sway bar end links circled in the photo in red.
Old 08-20-2018, 11:32 AM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
I can check at the Junkyard for you
Old 08-20-2018, 03:16 PM
AtomicDog's Avatar
AtomicDog
Please take a look at the salvage yard when you go.
If someone knows the part number for these brackets, please let me know.
Old 08-20-2018, 03:30 PM
MoparFanatic21
I'm going at the end of this week I have a personal junkyard and none of the trucks have that mount.
Old 08-20-2018, 03:46 PM
HeikIlm's Avatar
HeikIlm
HeikIlm is offline
If they are nowhere to be found, those mounts are rather easy to make from rectangular tubing.
Old 08-20-2018, 05:59 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,391 Likes on 3,131 Posts
C channel would be better.... Probably wouldn't be that hard to cut/bend some out of flat stuck either.
Old 08-20-2018, 06:07 PM
AtomicDog's Avatar
AtomicDog
I was able to find the brackets NOS - part 53038700 - hopefully, they will be here soon.
I checked my truck's frame and found the bolt holes for the brackets on each side towards the back of the rear wheel well area.
Old 08-21-2018, 12:11 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
I think you'll have a hard time with one side. I have links, but the driver side caused me to stop in my tracks - couldn't back out the bolt - I can' remember exactly what it was, maybe the gas tank?
Quick Reply: Can anyone share photos of a factory rear sway bar installed on a 2nd gen 2500 truck?
