Magnum fuel injection on LA block
Old Aug 26, 2018 | 12:15 PM
  #21
Sledder10's Avatar
Sledder10
This one maybe. Or this one. Both require different valve springs.
in laymans terms, what does one do for me over the other
tune required?
Old Aug 26, 2018 | 12:34 PM
  #22
Sledder10's Avatar
Sledder10
after expanding my search a ways (ugh lol) I found a shortblock for $200. short of taking it to a machine shop, what can I look for to make sure its a good base to build off?
Old Aug 26, 2018 | 12:40 PM
  #23
fj5gtx's Avatar
fj5gtx
Short block meaning the heads and intake have been off? If they've been off for a while, you need to ensure there are not corrosion problems with the cylinder and lifter bores. Inspect what you can, then pour some oil down on the piston rings and slowly turn the crank over and continue looking for corrosion or lengthwise scratches/gouges. Might have water in the oil pan too, if its been sitting outside.
I offer this advice often here. Find a running specimen and don't worry about rebuilding it. Just clean it up, change out the sensors/plugs/cap etc. The magnums last a long time, they tend to run decent enough for a truck. Save your $ for other stuff.
Old Aug 26, 2018 | 12:45 PM
  #24
The crower cam has a bit more lift, so, likely better power numbers. Comp cam likely wouldn't need a custom tune, but, would certainly take advantage of even canned tunes. (getting rid of torque management helps a fair bit.)
Old Aug 26, 2018 | 01:37 PM
  #25
Sledder10's Avatar
Sledder10
Out of curiosity if I stick with the 318 in it what would you recommend
Old Aug 26, 2018 | 01:46 PM
  #26
Pretty much the same thing. Its where you want your power, and will compliment the kegger nicely. Shorty headers would be good too.
Old Aug 26, 2018 | 02:12 PM
  #27
Sledder10's Avatar
Sledder10
I know there is a thousand threads on Headers... What's the consensus brand?
Old Aug 26, 2018 | 02:19 PM
  #28
Lotta folks like the pacesetter longtubes, but, those are relatively large primary tubes, so, more suited to the upper RPM ranges.
I think there is a thread about headers in the faq section???
Old Aug 26, 2018 | 02:40 PM
  #29
Sledder10's Avatar
Sledder10
Summit shortys $200 ftw lol
Old Aug 26, 2018 | 03:58 PM
  #30
AtomicDog's Avatar
AtomicDog
Pick up this book - it will help you immensely and help you in your rebuilding/Mopar small block knowledge quest
https://www.ebay.com/itm/How-to-Rebu...sAAOSwNSxVW47Q
