Maybe death wobble?
Old Aug 26, 2018 | 02:06 PM
cman9898's Avatar
cman9898
Default Maybe death wobble?
Hey folks recently my 97 1500 has devoliped an odd death wobble that doesnt have any pattern to it and is extremely violent I already checked my lug nuts and wheel play and had none but one of my stabalizers spins with little resistance the other doesnt if thats the problem whats the cheapest and most effective solution?
Old Aug 26, 2018 | 02:20 PM
Find out what's sloppy, and replace it. Track Bar? Ball joints? Steering parts? Bad shocks?
Old Aug 26, 2018 | 02:32 PM
cman9898's Avatar
cman9898
Whats the best way to test those parts without access to a shop and preferabbly wothout taking apart the front end it does seem to originate from drivers front also just did the steering pump and box
Old Aug 26, 2018 | 02:37 PM
Grab a friend, put 'em in the drivers seat, turn the ignition far enough so the steering is unlocked. (don't need ignition on, nor do you want the engine running.) Have your friend GENTLY rock the steering wheel back and forth. You crawl under the truck and see whats moving. Next, have your friend REEF on the steering wheel, while you watch what is happening underneath. Look for things that move, that shouldn't, or things that don't move, that should.
Old Aug 28, 2018 | 08:52 PM
cman9898's Avatar
cman9898
So upon further inspection we discovered that the track bar frame bracket has snapped. Since im likely to destro the boot for the track bar anyway how difficult is the third gen swap? Is it any cheaper than the drop bracket amd trac bar?
Old Aug 28, 2018 | 09:26 PM
Ouch. Most of the adapter brackets bolt to the stock track bar mount. I think they run in the neighborhood of 300 bucks, just for the bracket, may be able to find them cheaper...... Another member has a thread around here, REAL recently, where he fabbed up his own bracket, and welded it in place.
Old Aug 29, 2018 | 05:28 PM
cjames1173's Avatar
cjames1173
I got the "Death Wobble" really bad in Mississippi going from ATL to DAL. Lower Ball joints were the problem. Not too difficult a job except the first time, you gotta grind off the factory rivets to bolt on the aftermarket joints.
