V10 Motor Mount Replacement
Old Aug 26, 2018 | 09:27 PM
racefan41's Avatar
racefan41
Hope it was of some help. Watch out for the crank position sensor sitting right next to the passenger side mount too.
Old Sep 1, 2018 | 05:29 PM
Torxhead's Avatar
Torxhead
Update: I was able to change out the drivers side mount and figured that was enough as I figured out just how to do it. I plan to do the other side next weekend. I lifted the engine up enough to slip the mount out from underneath. The tricky part was that the mount is a very tight fit on the frame side. I was able to open it up a bit by using a short piece of 1/2" all thread to use as a spreader with nuts and washers on each end for the mounting ears. Still lining up the engine side bolts was a challenge also. The main mounting bolt has a class 3 fit to make things more fun. Thanks to HeyYou and Racefan41 for the guidance.
Old Sep 2, 2018 | 08:03 AM
racefan41's Avatar
racefan41
Glad to hear you got her figured out. Some jobs like that are one thing to look at, and a different thing when actually doing them. Was wondering what year your truck is....2500/3500?
Old Sep 2, 2018 | 01:48 PM
Torxhead's Avatar
Torxhead
I have a '99 2500 pickup.
