intermittent wipers, not intermitent
Old Aug 28, 2018 | 11:30 PM
fj5gtx's Avatar
fj5gtx
only contacts that made visible were turnsigs and flashers. which contacts were corroded that stopped intermittent wipers from working?
correction, I bought a whole steering column last week - so I have 3 of those MF switches laying around now.
Old Aug 29, 2018 | 01:42 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
In the part where it plugs in with the column harness it can be taken apart and inside there was corroded.
Old Aug 29, 2018 | 08:30 AM
fj5gtx's Avatar
fj5gtx
So you are saying take it apart further than I have it now, or just the pins that I have exposed in the picture?
Old Aug 29, 2018 | 11:48 AM
MoparFanatic21
Take it apart further. You'll see how it works when you rotate the end of the lever. Make due those contacts are clean.
Old Aug 29, 2018 | 06:09 PM
fj5gtx's Avatar
fj5gtx
Yep, dug the plastic out of the housing, unclipped the cover - found the white slider mechanism... cleaned those little contacts and where the slide... all back together... tried it... same problem. :-/ CTM back on the acquisition list... Of course, could be a bad ground for that thing too, I've had more than my share of bad ground issues.
Old Aug 29, 2018 | 06:16 PM
MoparFanatic21
Dang man I'm sorry that didn't fix your problem!
Old Aug 29, 2018 | 06:39 PM
fj5gtx's Avatar
fj5gtx
No problem, it was worth a try. Those do get gunked up quite a bit.
Old Aug 29, 2018 | 07:39 PM
MoparFanatic21
Yes they do. I don't think it's a ground as you said they do with just not on all the modis. Might be your CTM :/
