stalls
Old Sep 8, 2018 | 01:58 PM
Pmillsap's Avatar
Pmillsap
Default stalls
my dodge ram 1500 5.9 magnum stalls at lights when rpm drops. indicating light says evap system is at fault p0455, p0442. help. the truck runs fine when moving but when throttle is not being added the rpm drop to low and it stalls out. this is an automatic and been getting high grade fuel.
Old Sep 8, 2018 | 02:04 PM
Two separate issues.
When is the last time the throttle body was cleaned? The IAC well tends to get gunked up, and it just doesn't work the way it should.
Old Sep 8, 2018 | 02:14 PM
Pmillsap's Avatar
Pmillsap
never before have i cleaned or replace the IAC
Old Sep 8, 2018 | 03:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Pull the throttle body and clean it especially when the iac passage is
Old Sep 8, 2018 | 05:37 PM
Pmillsap's Avatar
Pmillsap
pulled cleand and hole in line to or from the carbon filter box found and replace. one of the 2 fixed the problem for now. thanks guys.
Old Sep 8, 2018 | 05:41 PM
MoparFanatic21
No problem glad you got it fixed!
