Video of noise.
Old Sep 15, 2018 | 03:00 PM
  #21
BrandonBuc'em's Avatar
BrandonBuc'em
Originally Posted by fj5gtx
You could remove the converter inspection cover and see if you have a cracked flex plate or loose converter bolts. You could also get a stethoscope to help you pin point the noise. Or you could just wait until it becomes much more apparent, although its usually better to catch stuff earlier.
https://www.amazon.com/Lisle-52750-S...70_&dpSrc=srch
Right I like to do preventative maintenance. But I'm not gonna go at it just replacing parts this time. I learned that the hard way. The stethoscope is a good idea.
Old Sep 15, 2018 | 03:04 PM
  #22
What year is your truck?
Old Sep 15, 2018 | 03:59 PM
  #23
BrandonBuc'em
97, most of the relevant info on truck should be in the signature. Unless it's not working for some reason.
Old Sep 16, 2018 | 03:25 PM
  #24
BrandonBuc'em
Were you going to suggest something?
Old Sep 16, 2018 | 03:30 PM
  #25
You could drop a 408 in there, just need the correct dampner, and flexplate. (360 is external balance.) Use the sensors off your current motor. You will need a tune for the 408..... and they ain't cheap to build either.
Old Sep 16, 2018 | 05:29 PM
  #26
BrandonBuc'em
Ok, I don't know if I'm gonna go that route or not. Just thought id ask. Thanks everyone for the help. I'm gonna give the stethosstethoscope a try
