Swapping a 1/2 ton to a 3/4 ton
Old Sep 15, 2018 | 03:56 PM
Jaws16's Avatar
Jaws16
Default Swapping a 1/2 ton to a 3/4 ton
Hey guys was just wondering if a 241 DLD transfer case will bolt up to a nv3500?
Old Sep 16, 2018 | 10:48 AM
Probably. I think the bolt patter is the same, along with the output shaft of the trans. Only problem you might run into, the 241 is a bit longer, so, may need a shorter driveshaft.
Old Sep 16, 2018 | 11:20 AM
Jaws16's Avatar
Jaws16
I'm gonna have to do drive shaft work anyway. I'm swapping 3/4 ton front and rear ends from a single cab long box into a single cab short box. The engine and tranny in the 3/4 are tired but it has the 4 10 gears that I need in the 1/2 ton. So I may need to move spring perches as well.
Old Sep 16, 2018 | 11:42 AM
Half ton truck use 2.5 inch springs, 3/4 ton use 3" springs. Need to change either the perches on the axle, or, the mounts on the frame. Think I would change the mounts, and use the 3/4 ton springs as well.
Old Sep 16, 2018 | 12:09 PM
Jaws16's Avatar
Jaws16
I guess if I'm going to this extent might as well keep the 3/4 ton springs too. I knew they were narrower but I was just taking one step out. Ha
Old Sep 16, 2018 | 12:16 PM
What year is your truck, and what year is the donor? There are some other differences as well.
Old Sep 16, 2018 | 12:34 PM
Jaws16's Avatar
Jaws16
Donor is a 95 my truck is a 96
Old Sep 16, 2018 | 12:36 PM
Cool. Shouldn't be a problem then.
Old Sep 16, 2018 | 12:39 PM
Jaws16's Avatar
Jaws16
Sweet hoping to get started on it this afternoon. Probably work on it in the evening after work.
