Installing rear lift blocks
Old Sep 18, 2018 | 10:48 AM
  #21
Call whomever you got them from, verify they are correct. (which might be an exercise....... if there aren't any markings on the blocks themselves.) Considering they wanted you to stack the blocks, but, doing so would have one block angled off from the other, that strikes me as a recipe for disaster. If the blocks shift due to the angles they are at, relative to each other, you would lose control of the rear axle, and 'bad things'™ would quickly follow.
  #22
AtomicDog's Avatar
AtomicDog
How about some photos of the blocks so that we can see what you're working with? Have you contacted the Rough Country with this issue?
Old Sep 18, 2018 | 10:59 AM
  #23
Grasscarlatemodel's Avatar
Grasscarlatemodel
Here are a couple of pics, Im gone get new u bolts and put the oem blocks back in. I will contact rough country and see what's up.
  #24
Grasscarlatemodel
Old Sep 18, 2018 | 11:05 AM
  #25
Grasscarlatemodel
Here are the blocks I got with my kit
https://www.roughcountry.com/universal-lift-block-kit-6592.html
Old Sep 18, 2018 | 09:17 PM
  #26
Grasscarlatemodel
Who knew that rear axle u bolts are so hard to find locally lol, anyway I just cleaned up the original u bolts and reinstalled everything back the way it came. Thanks for the input guys!
​​​​​​P.s. Anyone else who wants to level their truck, build your leveling kit, I regret getting a kit instead of making my own kit.
Old Sep 18, 2018 | 09:25 PM
  #27
Remember to re-torque your u-bolts after 100 miles or so.
Old Sep 18, 2018 | 09:27 PM
  #28
Grasscarlatemodel
I was planning on it
Old Sep 18, 2018 | 09:29 PM
  #29
Grasscarlatemodel
I really didn't want to reuse the old u bolts, but I was worried I'd get the wrong size online.
Old Sep 18, 2018 | 10:47 PM
  #30
AtomicDog's Avatar
AtomicDog
I'm in the process of swapping my drum brake Dana 60 rear for a disc brake Dana 60 and had noticed that one of my U-bolts had broken at the threaded area on one side. I ended up ordering a new set of U-bolts for it. The issue I found is ensuring that you get the right length. The U-bolts I ordered ended up being the correct items, but I noticed they came with the nuts, but not with hardened washers. Ended up ordering the hardened washers separately. Got the U-bolts and nuts from these folks - http://www.springsnthings.com/
