This one baffles me...
Old Dec 7, 2005 | 09:52 PM
steve05ram360's Avatar
steve05ram360
Default RE: This one baffles me...
ORIGINAL: Dodgeramman
My bad thought I read that it was charging at 15 volts [sm=bangbang.gif]sorry.
isnt the VR part of the PCM now? if not is it still in the Alt?
Old Dec 7, 2005 | 11:12 PM
clemson725's Avatar
clemson725
Yeah thats a dirty throttle body if you ask me.
Old Dec 7, 2005 | 11:53 PM
Socha_62's Avatar
Socha_62
It could be that Dodgeramman, it gets pretty high sometimes. [&:] I'll clean the TB and see where that gets me!
Old Dec 8, 2005 | 12:22 AM
DODGERAM808's Avatar
DODGERAM808
i have this problem everytime i disconnect the battery. i've been told that you just need to reset the computer. for me if i take the truck up to 70mph it resets the comp. this is what a mechanic told me the first time it happened to me.hope this helps
Old Dec 8, 2005 | 12:32 AM
Dodgeramman's Avatar
Dodgeramman
All I know is I had the same problem and it was the VR on my Ram. As for the VR being part of the PCM I could'nt say on 3rd gens. But if Daimlar follows the same system as the do with the Freightliners (which would make sence) it would still be in the Alt as they are with our 05's but then again they're Mercades motors.[sm=confused06.gif]
crusher135's Avatar
crusher135
clogged fuel lines?????? dirty fuel filter?????? might not be getting enough gas, bad fuel pump?
Old Dec 8, 2005 | 03:20 PM
Racinfan83's Avatar
Racinfan83
ORIGINAL: steve00ram360
I know that I had a '91 Dakota 4x4 and the Voltage Regulator was in the computer on that truck.....'cause it went bad on me and I had the dealer replace it. Believe it or not, it was cheaper to have them do that fix. I would think the regulator would still be in the computer if it was back in '91.
I still think this problem is with the TB.....
Old Dec 10, 2005 | 05:26 PM
Socha_62's Avatar
Socha_62
Well I cleaned it all up today, and holy crap! I can't beleive how dirty that thing was.
This is the bottom side, where the IAC goes its really gunked up.
Pulled the IAC out and it was caked with gunk. Cleaned that and the TB up really good. While I had the TB off thought I checked the Plenum. What I found makes me sad
Is this a bad Plenum? I don't think all that craps normal, but you guys tell me if it is
Old Dec 10, 2005 | 05:29 PM
Racinfan83's Avatar
Racinfan83
I haven't dealt with that problem yet.....but I don't think there's supposed to be oil in there...........
Old Dec 12, 2005 | 01:26 AM
Socha_62's Avatar
Socha_62
Oh come on, somebody has to know if its leaking!
