2001 ram 1500 horn/digital lights
Old 09-18-2018, 11:39 AM
CharlesShaheen's Avatar
CharlesShaheen
CharlesShaheen is offline
Default 2001 ram 1500 horn/digital lights
ok so I have a 01 ram 1500 4x4 my siginal lights was not working so I replaced the light sockets now my horn doesn’t work it used too and when I press the horn the pass. Siginal light comes on and when I turn the lights on the head lights the lights on the instrument Luster comes on for the siginal lights idk what it can be the wires where hooked up the right way plz help ASAP thanx
Old 09-18-2018, 11:43 AM
HeyYou is offline
Dodge Forum Administrator
Received 3,236 Likes on 2,985 Posts
You have some wires hooked up wrong. Need to re-check your work.
Old 09-18-2018, 03:02 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Or a bad ground.
Old 09-18-2018, 07:20 PM
CharlesShaheen
When I changed them there was only 3 wires per socket black,yellow,blk/green that’s how I hooked them up idk how I can track down a ground wire don’t even know where to look
Old 09-18-2018, 08:19 PM
HeyYou is offline
One of those three wires is going to be the ground. Two power feeds (running lamp, and turn/brake light) and a ground. If you don't have a service manual for your truck, get one here. Wiring diagrams will make your life MUCH easier.
Old 09-18-2018, 09:35 PM
CharlesShaheen
ok ty I will report back with an update
Quick Reply: 2001 ram 1500 horn/digital lights
