Transfer case replacement
Old Sep 28, 2018 | 09:05 AM
Seth2000's Avatar
Seth2000
Default Transfer case replacement
Hi guys I’m going to be atempting to replace my transfer case in my 2000 5.9 cummins I have a 2 post lift and trans jack is there anything I should watch out for or be prepared for any advise would be helpful thanks
Old Sep 28, 2018 | 09:28 AM
00t444e's Avatar
00t444e
It's pretty easy to do, disconnect the driveshafts, pull the vacuum line fitting on the top and breather tube, and take the 6 mounting nuts off and it should slide right off.
Old Sep 28, 2018 | 03:17 PM
HeikIlm's Avatar
HeikIlm
T-case isn't even too heavy. I didn't even lift my truck (stock height), nor used any jacks when I wrestled the t-case off from the truck and back. Two separate occcasions.
Old Sep 28, 2018 | 04:51 PM
00t444e's Avatar
00t444e
Yes the 231 and 241 can be done by hand, but the 271 is more of a challenge, I use a transmission jack on those.
Old Sep 28, 2018 | 10:36 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Our trucks never came with the 271 to my knowledge
Old Sep 29, 2018 | 09:13 AM
00t444e's Avatar
00t444e
Not the 2nd gens, it comes in the 03+ HD Rams and the 99+ Superdutys.
