Heater
Old Oct 1, 2018 | 12:28 PM
Tamuiel's Avatar
Tamuiel
No problem man. I have the opposite problem as you have Wally good heat no ac lol
yeah, my ac will freeze me out. Heater dont make sence. I manuaIly turned blend door didnt help. I also back flushed from return hose throughwater pump. Only green coolant came out easy
Old Oct 1, 2018 | 12:42 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
The blend door I think fails in the cold position so you would have to physically hold it there. You want to backflush from the nipples coming out from the firewall. I would say you still have air in the system then
Old Oct 1, 2018 | 01:03 PM
Tamuiel's Avatar
Tamuiel
yeah, i took off motor and turned blend door. I can feel and hear it open all the way. Then air went from cold to warmish. I could even hear a change in the sound of the air flow. Any idea how to get the air out? Thanks
Old Oct 1, 2018 | 01:49 PM
Ramman18's Avatar
Ramman18
Park it nose up and even jacked up on the passenger side. You want the radiator fill the highest point. Start engine with heat on full hot. Get to running temp for several minutes.
This, however, has never worked for me. Mine never needs bleeding. All I do is dump coolant in, drive it around, and all is good.
Old Oct 1, 2018 | 02:51 PM
Tamuiel's Avatar
Tamuiel
ok, thanks
Old Oct 1, 2018 | 06:40 PM
MoparFanatic21
Same here all I do is squeeze the upper hose until no more coolant goes in. Drive around for the day and then top it off.
Old Oct 1, 2018 | 07:07 PM
Tamuiel's Avatar
Tamuiel
so when you squeeze upper hose it allows more coolant to fit? Sorry for the dumb ?
Old Oct 1, 2018 | 10:09 PM
Tamuiel's Avatar
Tamuiel
i just reved up to 2500 rpm and heat started getting hot!!!!! ?????????
Old Oct 2, 2018 | 05:35 AM
MoparFanatic21
Yep. As it's sucking it in like a vacuum clear up to the thermostat. Then when it opens you have to add more do that's why I said after driving around
Did you replace the water pump? That's what mine did when it was failing on my Durango
Old Oct 2, 2018 | 08:31 AM
Tamuiel's Avatar
Tamuiel
previous owner said he replaced 3 years ago
