Dana 60 Rearend
Old Sep 30, 2018 | 01:53 PM
AtomicDog's Avatar
AtomicDog
What are the differences between the Track and Power lock
From Reider Racing's web site - if more information is desired, there are tons available via a quick Google search:
Power Loc - Durable four pinion gear design makes the Power-Lok one of the most positive, durable and aggressive limited slip units produced today.
Trac Loc - This two pinion, clutch style L/S unit improves traction significantly over conventional open differential and is suitable for both front and rear applications at an economical price.
Old Sep 30, 2018 | 06:56 PM
fj5gtx's Avatar
fj5gtx
BTW, when I was talking to a driveline shop - the first option they gave me was to swap in an open diff... so could be one of the POs had issues and just went the cheapest route available. Be aware there are setup clearances you have to deal with when changing diffs, and you should use a case spliter to rNr the diff on the danas.
Old Oct 1, 2018 | 12:15 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Heyi learned try new things from this thread. What is a case splitter?
Old Oct 1, 2018 | 02:12 AM
HeikIlm's Avatar
HeikIlm
Or spreader. It's a tool, which you use to remove/install differential from the axle housing.
https://www.google.fi/search?q=dana+...&bih=512&dpr=2
Old Oct 1, 2018 | 07:41 AM
00t444e's Avatar
00t444e
Are you sure it's a Dana 60 and not a Dana 70? I wasn't aware they put Dana 60s in the rear of 2nd gens trucks.
Old Oct 1, 2018 | 07:48 AM
HeikIlm's Avatar
HeikIlm
Dana 60 was used behind the V8's. 70 was under the autotrans 2500 w/diesel and V10, manual trans 2500 had a 80 SRW, 3500 DRW had a Dana 80.
Old Oct 1, 2018 | 07:49 AM
V-8's in 2500/3500's got the dana 60, diesel or V-10 with auto got dana 70, with manuals, dana 80.
