Stuck Hood latch
Old Oct 1, 2018 | 07:48 AM
Kerstingm's Avatar
Kerstingm
Default Stuck Hood latch
I have a 1997 Ram 1500 that my hood latch is stuck, any suggestions on how to get it to release?
Old Oct 1, 2018 | 07:49 AM
Is the cable just stretched out? If so, grab it with a pair of pliers, and pull it a bit more.
Old Oct 1, 2018 | 06:52 PM
Moparite's Avatar
Moparite
There was a recall on them.
http://dodgeram.info/tsb/recalls/973.htm
Old Oct 3, 2018 | 09:26 AM
Sheriff420's Avatar
Sheriff420
Happened to mine too. you need enough extensions to reach it from behind the bumper. Take out two bolts and the hood will open. Put a towel on the latch when you release it because that spring will fire it straight up, I found that one out in an exciting way. On mine it was the bar that attaches to it from the release on the bottom of the grille had the plastic piece break, I wrapped it up with some wire and put a hose clamp on it.
