Oil pan and gasket
Old Oct 2, 2018 | 08:47 AM
Wolf81's Avatar
Wolf81
Default Oil pan and gasket
Hey all,
first time truck owner, and I'm going to be changing the oil pan and gasket this weekend, any advice or problems I should be aware of, it's a '97 Dodge ram 1500 sport, 5.2, V8 Magnum with almost 120,000 miles.
TIA
Old Oct 2, 2018 | 08:52 AM
Not too bad of a job. While you are in there, might consider replacing the oil pump, and pickup tube as well.
Old Oct 2, 2018 | 09:33 AM
Wolf81's Avatar
Wolf81
Are those hard to change for someone with almost no mechanical skills?
Old Oct 2, 2018 | 10:12 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
No it's almost as easy at the pan. Take the pump bolts out and take the old pump out. Reverse to put the new one in
Old Oct 2, 2018 | 03:15 PM
Be sure to prime the pump before installation though. (which consists of dumping some oil down the outlet before bolting it back in place..... )
Old Oct 2, 2018 | 05:02 PM
MoparFanatic21
I use grease but yes I did forget that important step
Old Oct 2, 2018 | 05:52 PM
Wolf81's Avatar
Wolf81
Thank you, I really appreciate the help and information.
I think I'm going to enjoy coming to this forum with questions and looking for advice. This is exactly what the information that I needed.
