No spark on 1996 Dodge Ram 1500
Old Oct 12, 2018 | 10:14 AM
Iguanaman's Avatar
Iguanaman
Default No spark on 1996 Dodge Ram 1500
hello! Seen a lot of posts about this and none have helped me so figured I would try my own. 96 ram 1500 4x4, drove home one night fine, won’t start next day. Found “engine” fuse blown, replaced it, still cranks, getting fuel, won’t start. Sooo, I have now replaced crank sensor, cam sensor, cap and rotor, ecm and coil, still same condition, I’ve redone my grounds, when checking voltages at ecm I’ve got my twelve volts and five colts out, but don’t have 5 volts to distributor, and I have 12 volts at coil until I crank it then drops to nothing. My wiring diagram shows I should have an orange wire for 5 volts to distributor, and although it ohms out it is a blue wire , not orange at distributor. I’ve unplugged and cleaned all of my wire plugs and junctions. At this point I’m stumped! Any ideas would be greatly appreciated! Thanks in advance for any assistance !
Old Oct 12, 2018 | 10:51 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
An engine needs 5 things to start see what your are missing
1. Air
2. Fuel
3. Spark
4. Compression
5. Timing
Old Oct 12, 2018 | 03:21 PM
How did you check for spark?
Old Oct 12, 2018 | 03:40 PM
MoparFanatic21
I just seen you are missing spark my fault for the earlier reply. Like HeyYou said how did you check for spark?
Old Oct 12, 2018 | 05:23 PM
Iguanaman's Avatar
Iguanaman
I’ve tried a few ways, put a plug in plug wire, arcing coil wire to exhaust manifold and put plug in coil wire
Old Oct 12, 2018 | 05:38 PM
What brand crank sensor did you get? Was it for the correct style trans? (yes, there IS a difference between auto, and manual sensors.)
Old Oct 13, 2018 | 12:55 PM
Iguanaman's Avatar
Iguanaman
no idea on brand, got it at Autozone, did tell them automatic and it looks identical.
Old Oct 13, 2018 | 04:10 PM
Moparite's Avatar
Moparite
What condition is the battery in? Check engine light on? If so you can get codes here...
http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Oct 13, 2018 | 10:37 PM
Get a sensor from the dealer.......
Old Oct 14, 2018 | 07:49 PM
Iguanaman's Avatar
Iguanaman
Battery is new, I replaced battery cables, still nothing, removed distributor cap and made sure it’s turning, verified 5 volts to distributor, coil still has 12 volts when you turn on key, drops to nothing while cranking, back to 12 when you stop cranking, anybody have any ideas what this means? Truck only throws one code, 1765, which shows no 12 v to trans sensor, I clear that code, crank and it’s back, no check engine either.
