truck wont start
Old Oct 14, 2018 | 05:59 PM
Hunter Grimm's Avatar
Hunter Grimm
Default truck wont start
Okay so i replaced the distributor cap, rotor, spark plugs and wires and i believe in the process of removing or installing the cap i either unplugged something or disconnected something because i know there is alot of wires and sensors back there (95 dodge ram 1500 w/ the 318) and now the truck will try to start but sounds like it cant get fuel or theres no spark. And i started looking around and i noticed some oil on the backside of the engine near the distributor and egr valve so i looked under and there was oil dripping on the ground and it wasnt just a couple spots it left a damn puddle about the size of a piece of tile. i know its coming from the top backside of the motor but i just need some help finding out what the problem is
Old Oct 14, 2018 | 07:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Need to find out what you are missing. The cam sensor is back there (under the cap) so you could have unplugged that
Old Oct 15, 2018 | 07:23 AM
Check the oil pressure sensor for the leak.....
