trans problems
Old Oct 23, 2018 | 09:01 PM
This phone is about to go out the window
You should be used to it's 'creative interpretation' of your typing by now.
Old Oct 24, 2018 | 01:03 AM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Problem is I reply while I'm at work (only free time) and I don't have the time to proof read
Old Oct 24, 2018 | 09:04 AM
bgortney15's Avatar
bgortney15
Default Reply
Spark test went good all 8 had good spark
Old Oct 24, 2018 | 09:09 AM
So that leave fuel. Ohm out your injectors. Should be right in the neighborhood of 12.
Old Oct 24, 2018 | 03:05 PM
bgortney15's Avatar
bgortney15
Default Reply to hey you
Injectors tested witching spec of my manual i’ve been through everything but the trans guys
Old Oct 25, 2018 | 07:43 AM
Would be interesting to see if you had any pending codes.
I am fairly certain it's an engine problem. (as sure as I can be without actually laying hands on the truck.....) Yours is behaving exactly the same way mine did when I had two dead cylinders. (plug wires routed wrong, my bad.....)
