4wd Drive Issue???
Old Oct 26, 2018 | 12:14 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Originally Posted by 00t444e
For cheap you can permanently lock the CAD and not have any more issues, or you can convert to the Posi Lok cable actuator. I would never want to rely on a vacuum system for my 4x4 to work.
I had the Posi Lol on another truck and hated it. Cabin isn't bad but I'm probably going to convert it to electric
Old Oct 26, 2018 | 12:22 PM
00t444e's Avatar
00t444e
You can permanently lock it for free.
Old Oct 26, 2018 | 12:41 PM
MoparFanatic21
How would you do that? Do you know how bad that affects gas mileage?
Old Oct 26, 2018 | 12:54 PM
00t444e's Avatar
00t444e
Take the actuator off slide the fork over and put some washers or a spacer on it to keep it in place. It has no effect on fuel mileage, Jeep did away with it in 91 on the XJ and 97 on the Wrangler, the straight axle rams got rid of it in 02, none of those had any fuel mileage drop because of it.
Old Oct 26, 2018 | 01:15 PM
MoparFanatic21
Slide washers on the shaft??
Old Oct 26, 2018 | 01:31 PM
00t444e's Avatar
00t444e
Yes or a solid spacer.
Old Oct 26, 2018 | 02:25 PM
MoparFanatic21
Ill look into that, thanks!
Old Oct 26, 2018 | 02:52 PM
I think you can just pull some of the snap rings, flip the fork over, position it in the right spot, then put the snaprings back on to hold it there.
Old Oct 26, 2018 | 03:47 PM
MoparFanatic21
What if I put a vacuum in the reservoir then cap both ends? The vacuum should stay
Old Oct 26, 2018 | 06:03 PM
00t444e's Avatar
00t444e
It isn't that great of a seal, it wouldn't hold for long.
