Aftermarket Transmission Oil Cooler
Old Oct 25, 2018 | 02:11 PM
Charlie Laforge's Avatar
Charlie Laforge
Question Aftermarket Transmission Oil Cooler
I have a 1999 dodge ram 1500 that is getting the transmission rebuilt. When I dropped the pan the ATF was silver and full of metal debris. I need to replace the entire radiator as the trans cooling lines are an integrated part of the radiator and i suspect the radiator is full of debris (and i was told to get it replaced before i get the rebuilt one back). My question was, is there and aftermarket transmission oil cooler that is on the market meant for my truck? Any advice would be awesome.
Old Oct 25, 2018 | 02:14 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
And transmission cooler will work. Even the one from Advance Auto, just takes a little bit of time to install.
Old Oct 26, 2018 | 10:26 AM
Charlie Laforge
When you say a bit of time do you mean just getting the lines to fit for the aftermarket oil cooler? I suppose you could run some sort of extension from the oil cooler to the lines themselves and it would work that way?
Old Oct 26, 2018 | 10:45 AM
cruzer55's Avatar
cruzer55
Just have the shop install one of theres or recommended.Much easier plus a warranty.Just a thought.................
Old Oct 26, 2018 | 10:48 AM
Charlie Laforge
That would be the route to go... however the transmission is being rebuilt as we speak and I have no way of getting the entire truck to a shop at this point.
Old Oct 26, 2018 | 12:16 PM
MoparFanatic21
If you decide to install one yourself let me know I'll help you through the process
Old Oct 26, 2018 | 12:37 PM
Charlie Laforge
Have you installed one yourself? I was just curious if anyone had a bought one that worked for them?
Old Oct 26, 2018 | 12:40 PM
MoparFanatic21
I've done them before on vehicles. They all will work for you. You just need a decent sized one since it's a truck.
Old Oct 26, 2018 | 01:04 PM
Charlie Laforge
Right, It also needs to clear the the gap, so it needs to fit between where the hood comes down and the radiator
Old Oct 26, 2018 | 01:08 PM
Charlie Laforge
https://www.partsgeek.com/kw66z5h-do...ion+Oil+Cooler
Would something like this work for my truck?
