Dim lowbeam headlight
Old Oct 26, 2018 | 01:46 PM
leftfield's Avatar
leftfield
Default Dim lowbeam headlight
High guys, I have an early 98 Ram 2500 xcab 5.9 diesel. I converted my headlights to the sport model a few years ago and they seemed to work ok. I'm not sure which company I bought the headlights and wiring kit from. Recently the drivers low beam is very dim but high beam works fine. When the low beam is on the high beam seems to be on dim as well. I checked the fuse under the hood (40 amp I think) and when I pulled it all the headlight power went out, plugged it back in and it was the same as before...still dim. I tried switching the relays and nothing changed. Any ideas on what might be wrong? Thanks
Old Oct 26, 2018 | 02:28 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Are they just regular headlight bulbs?
Old Oct 26, 2018 | 03:06 PM
leftfield's Avatar
leftfield
Yes just regular headlight bulbs
Old Oct 26, 2018 | 03:10 PM
Check the grounds.
Old Oct 26, 2018 | 03:50 PM
MoparFanatic21
Check the grounds.
+1 on checking grounds
Old Oct 26, 2018 | 03:55 PM
leftfield's Avatar
leftfield
How would that relate when the high beam works just fine? Is there a separate ground?
Old Oct 26, 2018 | 08:01 PM
MoparFanatic21
No there is not but it still can cause problems. You either have a bad bulb or a wiring issue on the ground or hot side.
Old Oct 27, 2018 | 10:12 AM
leftfield's Avatar
leftfield
Ok so after months of this last night the low beam brighten right up. I'm not sure if it happened while switching from high beam to low or not. One thing I did notice is that the (keep in mind that these are the sport headlights) high beam bulb is lit up dimly while the low beam is on. I'm going to try and get out there and do it this weekend so if you guys have any specific info on where and which ground connections to check that would be great. Thanks again
Old Oct 27, 2018 | 12:56 PM
MoparFanatic21
Headlight grounds. Also check the power wires for exposed copper. Only way for the high to be lit is it's getting juice. You may have absorbtion from the low beam wire
