Timing chain help
Old Nov 9, 2018 | 01:50 PM
AtomicDog's Avatar
AtomicDog
No snow will lay here....yet. the only issue I had working on older vehicles her in the rust belt was my 01 Ram. When putting the lift kit on I had to cut every control arm bolt and even the rear upper shock bolts. No big deal got them replaced at the local hardware store. Cam bolts I paid $48 at advance and the washers aren't big enough so I can't adjust my axle (which I think is causing my shaking at 45 and above but it could be a tire out of balance). I finally invested in a heat induction tool, which should stop that problem.
Here is the link for anyone who is curious:
https://www.amazon.com/Bolt-Buster-B...c7594fb8365937
Interesting tool. Thanks for sharing. For now, I'll stick with the acetylene torch or a map gas torch. I've had great success with them.
Old Nov 9, 2018 | 04:26 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
They are really good and I use them to. The only problem is if you have a rubber bushing you are trying to save it will catch it on fire. This tool won't. Basically it's a glorified heat gun that sends the heat through the bolt. I will probably only use it a few times over my life but it's worth it in my book to save from ordering shocks (since my truck is lifted) as I can't have a vehicle sitting that long
Old Nov 10, 2018 | 10:22 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Old Nov 10, 2018 | 11:08 AM
MoparFanatic21
Originally Posted by TNtech
Eric O! I watch his channel and never seen that video! I haven't even got mine yet lol
Old Nov 10, 2018 | 12:44 PM
TNtech's Avatar
TNtech
This is TN...that's all you need here lol.
If I had to work on that rusty, barnacle infested BS every day, I would find another line of work (:
Old Nov 10, 2018 | 02:49 PM
dapepper9's Avatar
dapepper9
I just pull the plugs out so you're not fighting compression and use the crank bolt. Can practically turn it over by hand at that point, wont break the bolt that way.
Old Nov 10, 2018 | 06:08 PM
MoparFanatic21
It's not bad here honestly. I originally am from Texas and believe it or not it was harder to work on vehicles down there. The worst part when I did this as a living was being under it and a chunk of snow hits you in the face. Now when I work in mine I let it sit in the heater garage for about 1-3 hours to dry it out.
Old Nov 10, 2018 | 06:35 PM
AtomicDog's Avatar
AtomicDog
My sentiments exactly!
Old Nov 16, 2018 | 08:06 AM
jlake4130's Avatar
jlake4130
Like dapepper mentioned, pull the plugs and the engine will rotate MUCH easier.
