After the clutch, now engine problems
Old Dec 9, 2005 | 01:30 PM
steve05ram360's Avatar
steve05ram360
Default RE: After the clutch, now engine problems
the crank sensor is on top of the bell housing right behind the passenger side head. the cam sensor could also be the problem and it's located in the distributor.
Old Dec 9, 2005 | 02:14 PM
dodge_boy31807's Avatar
dodge_boy31807
Would it be better to check all the sensors first and then go to the spark plugs. Or what way is teh best route to go.
Old Dec 9, 2005 | 02:51 PM
steve05ram360
1st check for spark, no spark, then go to the sensors. you can also get a automotive stethescope and put it on the injectors to see if they are opening & closing.
Old Dec 9, 2005 | 07:08 PM
dodge_boy31807
Can you pull the spark plugs out,attach the wires back to them, and then lay them onthe block and see if they are givin spark?
Old Dec 9, 2005 | 07:17 PM
steve05ram360
yes, make sure it's making good contact with the block when you do it. it's easier if you have a timing light though.
Old Dec 9, 2005 | 07:40 PM
Tani1500's Avatar
Tani1500
check your crank sensor, i just put a clutch in mine and broke it off with out even Knowing it. its located on the right side of the trans on the top. I hope you did break your though. cost me $110. for a new one. let me know if you need any help.
Old Dec 10, 2005 | 03:25 AM
dodge_boy31807
it is an actual thing that you plug something into on the transimssion. Because there was things that I had to plug in when we put the tranny in.
Old Dec 10, 2005 | 12:27 PM
dodge_boy31807
Is the crank sensor on the engine, bellhousing, or the transmission? I looked around and the only thing that I have found are two plug-ins on the transmission.
Old Dec 10, 2005 | 01:40 PM
steve05ram360
it would be up by the passenger side of the motor right behind the head. it's mounted to the back side of the engine if I remember correctly. find the lower rear corner of the head and run your hand to the back behind it and you should feel the wires.
Old Dec 10, 2005 | 01:55 PM
dodge_boy31807
Is it something that I will have to pull the engine out to replace if it is damaged? Could it be that the wires have pulled out or it has come unconnected? Does it just plug in and that could just be my problem?
