01 Cab Swap? Should I?
Old Dec 24, 2018 | 01:24 AM
Bailey Miller's Avatar
Bailey Miller
Default 01 Cab Swap? Should I?
So my cab is in pretty crappy shape, it definitely needs rockers. The fenders are pretty messed up now that I look at it , it needs a patch underneath where the e-brake line is. The driver side door doesn't close all the way, the driver side rear door doesn't open and my hood is starting to lose it's paint. So I found an exact black 01 with not a speck of body rust for 1500. The bed is a long bed so it's of no use to my 6.5 ft bed but should I definitely pick it up for my truck? Is it easy to do a cab swap if I were to get it done at a shop? I know they're some heavy bastards
Old Dec 24, 2018 | 07:58 AM
Paying someone to do that is going to be expensive. You could likely find a rust free truck, that just needs a good motor, and spend less money.
Old Dec 24, 2018 | 12:25 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
I'm doing it in my garage. Take HeyYou's advice.
Old Dec 24, 2018 | 10:52 PM
Bailey Miller
Alright ill take your word for it
Old Dec 25, 2018 | 01:05 AM
MoparFanatic21
If you can find a cheap cab and can let your vehicle sut while you work on it or learn how to, then do it!
